Disables the ICMP IPv6 reply to multicast or anycast echo request.
ignore-multicasts | Specifies to reply to ICMP echo requests destined to an IP multicast address. Default is ignore (disable). |
ignore-anycasts | Specifies to reply to ICMP echo requests destined to an IP anycast address. Default is ignore (disable). |
Ignore (disable).
Use this command to disable ignoring a reply packet to multicast or anycast echo request.
The following example specifies to reply to ICMP multicast echo requests:
disable icmp ipv6 ignore-multicasts
This command was first available in ExtremeXOS 31.3.
